staticy hu while playing a cd
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif ur sig is kinda ghey.....//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
pioneer has had static issues in the past but i'm not sure on that particular amp. try re-grounding the headunit
Oh. I'm sure it's not the amp. Because the speakers that I here static from is from the hu. I only have one amp, and it's for my sub. This is my home system. Which is all connected to a power supply. It's basically the same install in a car system.
Oh. I'm sure it's not the amp. Because the speakers that I here static from is from the hu. I only have one amp, and it's for my sub. This is my home system. Which is all connected to a power supply. It basically the same install is a car system.
What kind of power supply? How much current is it rated at?
By current I mean how many amps is it rated at?
If you are trying to draw too much current (more then the power supply is rated at), the power supply won't be able to provide it, and you can burn it up. Also when you draw more, it can give you static.
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
myjaja
