static noise!
phychokid079
Im thinking it might be a loose wire on my rear speakers because they started to static like anything after volume 20 after reorganizing my wiring and my amps...
my front still works fine...but im guessing i loosened up a wire because they were working fine before i reorganized
Im thinking it might be a loose wire on my rear speakers because they started to static like anything after volume 20 after reorganizing my wiring and my amps...my front still works fine...but im guessing i loosened up a wire because they were working fine before i reorganized
what???
haha ok so i took disconnected every wire out of my 4 channel amp and my mono channel amp and moved my subs...and then repositioned the amps...and then rewired everything.....after i rewired everything my rear speakers just started staticing after putting it at least 20 volume....
but everything else works fine...i dont think the speakers are blown...
Do you think its just a loose conneciton of a wire somewhere
phychokid079
phychokid079
Tucson, AZ
phychokid079
michigan born
    May 14, 2026
michigan born
    May 14, 2026
