Startup Thump
vipervin
www.vipervin.com
when i startup my car, the subs annoyingly thump. i am pretty sure its the sub amp cuz 1) its old, and 2) my newer component amp doesnt thump.
aside from getting a new amp, is there anything i can do about the thump? does the thump cause any subwoofer damage? .. cause it sounds like the sub is momentarily crying for help //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Did you take all of your grounds wrap them around each other and secure them to one point on the car?
This is the most common reason for the "thump"
Remove the ground, sand off the paint at the ground point or move the ground to a new location.
If the grounds are all together, try seperating them.
my ground is good as it gets. its sharing the ground point with my component amp.
i will try separating the grounds and see if that works.
jntar- would i be able to use the remote wire from my HU to the component amp, and then from the component amp to a relay to my sub amp?
HU ---> Component Amp ---> relay ---> sub amp
OR
HU ---> relay ---> component amp and ---> sub amp
OR
I would do the one I bolded...or you could even tap into another source like ignition.
HU
Relay
Comp and sub amp
It may be noise getting through your HU and traveling along your RCA to your sub amp.
Try disconnecting your RCAs from your sub amp and turn your stereo on (volume off). Turn the sensitivity (gain) of your amp up and start your car. Do you hear a thump or alot of noise? With the gain turned up you should expect some noise...but you shouldn't hear your car revving. If not, you have a good sub amp ground. The issue is either coming from your HU or your RCA.
Turn off power reconnect RCAs and pull out your HU to disconnect the RCAs from it. Turn stereo on. Any thump or noise? If not, it is your HU causing the problem.
Possible HU issues can be:
Antenna - disconnect to test
ground - try creating your own ground to the chassis
deffective - something internally in your HU may have screwed up and it needs to be serviced.
vipervin
www.vipervin.com
vipervin
Bay Area, CA
snoopdan
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
