Starting to collect equipment...
Beentown
Going to be getting a new Suburban. Wanted to get your opinions on sub setup. If you had the space for the correct box which setup would you go with?
1500-2000 watt amp with:
2 SA 15's
Or
1 SA X-15
Which setup and why?
Sent from my SM-G950U using Tapatalk
Theoretically which should be louder? Any real difference in SQ?
I like the idea of dual subs but I have never owned a really high excursion sub. All my other vehicles have 2-10's in them with 500 to a 1000 watts running them.
Back when I used to compete I used multiple efficient subs with lower wattage. Subs being able to take multiple thousands of watts is something I haven't experienced.
I’ve had sa series and x series. And since you asked why instead of just saying two sa 15s heres my take. In a proper box the sa will get just as low as a x(pretty dang close anyways) and yes a x can play higher notes. It’s not a low end only monster but it does business under 35hz. I can personally tell you unless your throwing a real 2k rms to the x 15 it’s a waste of your money. The two sa 15s in 8-9 cubes on your power with a 10” aero port tuned to taste would sound really good on your power. Please do not think a high excursion sub is some spl db gaining unicorn. The sa has 19mm Xmax one way and the x has 30mm one way. On your power you’d be lucky to get the x to 19mm each way. Go with the sa 15s. If yard sale ever opened again that’s where I’d buy. I miss yard sale and wasting money I don’t need to spend:crying:
Thanks all. I assumed the 2-15's would be louder but without ever owning a SPL sub other than the "Mule" back in the day I thought I would ask.
Just happened across some old pics of my loudest rig.
6 Soundstream Rubicon Subs (ran Mules and other Soundstream subs and the Rubicon were the loudest in my particular set up)
2 Soundstream 10.2 amps
Rubicon 4 channel powering Soundstream SPL components.
I ran all Xtant until I ended up sponsored by my local shop and Soundtream. Wish I had pics handy of the inside of the box and other amp racks/wiring.
Couple other builds from back then...if you guys wanna see more I may be able to dig them up.
First "real" system I did. RF 15's in a different Probe GT.
The 2 sa15 will likely be louder
Unless you fail utterly and completely at box building the 2 SA 15s will be far louder than the single X 15.
Every one I can think of is the exact opposite in fact. There's almost no practical application for most of those except for showing off to your buddies "how much flex" you get when playing them below tuning.
The X is absolutely NOT an SPL sub by any stretch of the word. Really I'd consider the SA series a far better SPL sub than the X. If you like Sundown and want proper SPL application you're looking into the Z (with the SPL softparts) and even then you'll be hard pressed to get one louder than the pair of SA assuming you're not limited on space.
Not space limited within the parameters being discussed.
I like the old school pics. Post more
I'll see what I can dig up. Found this one on my Photobucket. We were competing at Finals in KC and someone was apparently pissed at this dude or just being punk kids....pulled almost all of his RCA's. It was a mess.
Some more of the guys I was competing against (none of these were my vehicles).
---------- Post added at 05:14 PM ---------- Previous post was at 05:13 PM ----------
Sorry about the quality but these are pics of pics from 1997.
Here is the inside pic from the "Bump" sign truck. Same subs as mine but wedged. He and I ran pretty close to the same SPL.
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
ok so i realized the one u gave in the example did the same video stuff so i see the one mentions 13 band equalizer but the other has "higher"...
17
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
360
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
  • Locked
I almost passed out reading this one. LOL!!
Beentown
Beentown
Central, OH
hispls
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
