SSA Aero Ports
2 3" aero's should do but personally I'd use a single 6".
Yeah I want to use a single 6, but it'd look like a chimney because the length required is longer than the box has room for...Plus they're $40 whereas the others are ~$10 ea.
Not sure how I feel about having a chimney....
2 4" will give u around 25.12 port area definatly go with this its around 8.75 per ft
Looks like I'll go 2x4" or 1x6" but i'll be stuck with chimneys...(external sections...) not very clean looking...want a better option if I can find one.
Subs back, port(s) up.
16"height external, 14.5"height internal. Tuning 30hz.
Box is 16h x 17d x 39w with an amp rack alcove that takes up 16h x 4d x 22w on the rear,right side.
Purple area is empty space for amps. grey circle is for port(s)
why not tune to 34-35hz and get a higher db gain and be able to fit a 6" aero port. you a not losing much if anything by tuning 4-5 db higher.
4-5hz higher can make a pretty big difference in the low end.
Elbows and you can fit whatever length you want //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
True, though trying not to spend on ~$100 on port pieces lol.
Yeah. ~32 would be the highest I'd want to go with these, and that's pushing it. Though can't argue with db gain.
i would go with two four inch ports i used to psp in a recent set up for two type rs 4.0 cubic feet tuned to 32 hz and it performs flawlessly. i would not advise the 3 inch ports over the four.
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
Bumpin' Goalie
Magic 8 Ball
Bumpin' Goalie
TN & Travel
Sneakysh13
    May 22, 2024
    May 22, 2024
