squel noise... not engine
abra
1st. Hi
isnt this how we all meet, when stuff goes wrong
details of system
92 ford bronco
1 kicker kx200.2
2 kicker kx1200.1
2 kicker L7 12's 1ohm load per amp
1 power accoustic 6.5 comp. system(i think, box is at home)
problem:
on my kx200.2 powering my 6.5 comp
have a squel when gain is turned up to 1/4, only on left channel
this is what i have done so far.
1.removed speakers from door and place on tail gate and tested
2.replaced... rca,head unit( it needed it), wires
if this helps:
1.speakers are softer on right side, are harsh on left side
2.noise doesnt happen when i unplug left rca, speaker still hooked up
3.no squil when low pass is on, only on off and high
other than those, spl is awsome:crazy:
theres some other threads on this i think
1st your hu might not be grounded good.
2nd if one side is louder than other then your balence on ur hu might be off try to adjust it
i starting to think the samething...bad channel
tried the ground idea frist, just forgot to mention it
i bought it off a guy on ebay.
i contacted him today, he told me to send it back and he will refund or ship me out a differant one.
still have to test all idea's just incase he says its ok
taken to a local shop to have it look at., for proof //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
will keep you all posted
switch out amps with my other kx200.2 from other car..
the ****er is still there:crying:
i starting to think i should look into my grounding.
now:
2- 2gauge running 6 ft to same ground point
tomorrow:
2 into dist. block than to grounding point
if this isnt it than, i look into my crossovers
sounds like you have ground loop noise... if im not mistaken, its from separate electrical devices being grounded at different points, and it may be cuz ur amp and HU arent grounded at the same point... im no expert on grounds, but just my 2 cents based on what ive read... the forums have taught me a lot, but i too have a lot to learn. My amp in my acura does the same thing... i think i may have a blown channel though, but i dont have time to mess with it, the clutch is broken anyways so i dont drive it... lol
abra
abra
kansas city
phantom240
Mike Mccabe
