SQ HDC4 15" amp?
Hi guys recently I bought one HC4 15D1 to use in a spl competition and I want to get a good score in the termlab.
The box that I planing to build is tuned to 45hz in a 3.89cuft with a single 8" aeroport. And I don´t know if my kicker zx2500.1 amp will work good to do that, or I need to use another amp?
I would sell that amp and buy a sq 3500.1 does around 4300rms and you can wire it to .5ohm to keep rise down. Your kicker you have to wire at 2ohm after rise and what not you won't even see half power.
I second this motion ...perfect match..gona have to beef up the electrical if you havent already
I have 6 kinetic hc600 in the truck and one yellow top in the front... but I runing my stock alt, but I planning to upgrade my stock alt to 250 or 300 amp alt. an 0 gauge around all the car......
What sort of competition? What org? What power class? IMO there's nothing wrong with the Kicker 2500.1 and from my experience you'll have a hard time getting a single sub down to half ohm (if it isn't quad coil). More likely you'll wire down to half ohm and rise up to around 2 ohm making a D1 ohm coil good for daily or to wire parallel for comps.
All hdc4s are d1 so he can wire to. 5 or 2 but it will take it at .5 daily if he has the electrical to back it
lextuninghn
lextuninghn
Miaimi, FL
lextuninghn
