SQ competition tips
  • 2
AC units are nice. Where to set it is a complicated question. It's always good to make a nice flat response using an RTA (Real Time Spectrum Analyzer). From there, adjust as you see fit, what sounds good to you. I don't believe IASCA has points for a flat response on the RTA anymore, so whatever sounds best is your best bet.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
6
SasquatchBump
SQ is better
SasquatchBump
Pendleton, Oregon
Mark_ab
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
