Splitting RCA from head unit
RCA outputs on amps are just splitters, unless marked otherwise. Diagram is good. That 1220s 620x1 @2 Ohms is not bad at all. I doubt more power will be needed. Just mind how you wire the sub to it.
Ah, maybe one more question about the signal, still not clear to me. The Alpine amp I'm sending the RCA to doesn't have an RCA out. In this case would you get a dual RCA splitter in order to send the signal to each amp individually, or would you send the signal to the Avionixx first, which has RCA ins and outs? Not sure if the sequence of the amps matters.
danielnews
CarAudio.com Recruit
danielnews
San Diego, CA
danielnews
Mike Mccabe
