Split 1 remote wire to 4?
wong05tsx
Right now I have a remote turn on ran from my HU to my rear, where I used a butt connecter to split it into two signals, one for the 1500 and one for the 100.4.
In a few days I'll be putting my rear fill in and connecting the 100.2 (will then be split into 3 signals).
In about a week, I have a custom made balun (converts my stock HU's balanced differential inputs into unbalanced, so that I can use unbalanced amps) which will also need a turn-on lead.
Will it be safe to have the one run split into 4 turn on's?
I read that 2-3 is fine, but I'm not sure if 4 will be pushing it //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
if possible use a relay
if possible i'd like to avoid this since I already used all the outputs of my d-blocks.. i COULD probably fish a little wire in there with the other connection, though.
In event that I do use a relay, do I need to fuse the positive to relay?
Also, if anyone has a diagram of how to connect one, that'd be great, googles references is too broad :\
Relay -
Remote turn on to [ ? ]
Ground to [ ? ]
Power (fused?) to [ ? ]
Output to accessors [ ? ]
[ ? ] = #'s i think? I remember reading on this before but I deleted my bookmark
Thanks for the help
85 - Remote turn on from Hu86 - ground
30 - Fused 12v
87 - output to amplifiers and such
87a - not used
thanks //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
and lastly, what size fuse to use?
wong05tsx
wong05tsx
Oakland, CA
DarkFox
