Spl "800.2"
  • 2
RicksI30
1. Product:
SPL "800.2" Amplifier Screwed up the date in the pic btw
2. Specs:
Gorilla Series Class A/B 2-Channel Car Amplifier
RMS Power Rating:
4 ohms: 150 watts x 2 chan.
2 ohms: 180 watts x 2 chan.
Bridged 4 ohm: 360 watts x 1 chan.
Max power output: 800 Watts
Regulated MOSFET PMW power supply
Bass Remote Details (Wired remote bass level control not included)
All connections on the front side for easy installation
LED power indicators
Bass Boost (0-12 dB bass boost at 45 Hz)
2/1 channel operation
Bridged Synchronization (Strap amps together to double your power!)
Preamp RCA outputs
3-Way system protection circuitry (thermal, overload, and short protection)
Brilliant silver texture coat finish
Heavy duty die cast aluminum alloy heatsink for extreme heat dissipation
Silver-plated RCA level inputs
Silver-plated screw terminals
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (30-250 Hz, 12 dB/octave)
Subsonic Filter (12 dB at 15-50 Hz)
Frequency response: 10-30,000 Hz
Dimensions: 10"L x 8-1/4"W x 2-1/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
3. Description/Condition:
Good condition, still has plastic film on it.
4. Price: :
55 shipped obo
5. Pictures:
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
Highest my car has done is a 156. I have 1200w on highs and recently swapped the mids to pro audio mids. This was a challenge as I find many of...
RicksI30
RicksI30
Tucson, Az
RicksI30
