no 130.779 db's is lowon WinIDS with 3.5cubic with 4 4" ports tuned to 45hz puts port length at 16.26 with max spl @ 130.779 @ 52hz does that sound ok? //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
He is referring to the "theoretical" number WinISD spits out. This doesn't take into consideration cabin gain. I still don't see it being astronomically high, but probably a good bit higher than 130.no 130.779 db's is lowwith 2 10's u should atleast be in the 140's
i did 142.5db's with 2 fosgate he2 10's and i did 142.3db's with 2 jl 10w3's
and that was in a bandpass box tuned at 35hz with 1200-1500watts powering them
i know i could have hit a higher number if i made my port lenght smaller
but from what i know about spl boxes.....u need to make a large box and use large ports.
1.5cubes and atleast 40square inches of port per 10 ..as far as power i know u have a good amount on tap....
80
1.5cubes per with 40square inches of port per puts the tuning somewhere around 59hz if im not mistaken doesnt that sound a bit high?but from what i know about spl boxes.....u need to make a large box and use large ports.1.5cubes and atleast 40square inches of port per 10 ..as far as power i know u have a good amount on tap....
80
