x2Or you can just open the throttle up? I know my Single Cab Dakota RT with the 5.9 v8 and some mods, including 4.56 gears, I just give it gas, and the whole truck goes sideways.
that's probably because you're going against the tread and it's not designed to grip in reverse.I can spin out good in reverse, just not forward. In reverse I don't even have to power break.
Can't do it forward, just tried it today.
Well yeah, I can do that, if I go turn and romp on it, I can spin out really good. But I can't do it on a straight away.hmm..
Rather easy in my Blazer to spin out.. When I am pulling out from somewhere, I just stomp the gas and turn the wheel the direction I want to go..I thought most vehicles were capable of spinning this way..
I grew out of this real quick. I did it one time leaving the bowling alley when I was 16..It was raining and I thought it would be cool. I lost control and almost hit a lightpole. Not cool.
You're just going to have to power brake it. Do what i said, and then when you want to go let off the brake. Experiment with letting off the brake at different paces.Well yeah, I can do that, if I go turn and romp on it, I can spin out really good. But I can't do it on a straight away.
I tried power breaking it today. At one point, It will slip very very little, and grabs and goes. Not even 2 inches of tire movement on the slip I dont think. Then again, the pavement around here is very rocky and has lots of traction. Might go to a newly surfaced parking lot to see if that changes anything.You're just going to have to power brake it. Do what i said, and then when you want to go let off the brake. Experiment with letting off the brake at different paces.
Another trick that works is to put some oil under the back tires... not a lot though.
