SPECIAL SAX-100.2 OFFER, * Limited Offer until April 20th!
This is an awesome deal! This amps are killer and the price cant be beat. Even at the regular price!
Do yourself a favor and check out Sundown if you havent already! Sundownz is the owner of the company, how many brands do you know that the owner comes on these forums to share knowledge and answer questions?
I was playing with one on my test bench with a clamp meter on Bass Mekanik 5.0 track #17 which is a consistent bass track.
Averaging ~450 watts @ 8 ohms actual, 4 ohms nominal load (7.5 amps / 60 volts) on that song *laughs* About 1/2 gain and max un-clipped volume on my Alpine test bench HU. No distortion testing was done, so don't take that as a low THD measurement by any means -- just my stress test before shipping it out.
I want one now! All moneyz bein spent on hu right now though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I may be too late
im going to be buying one!! But i have to wait a day so i can get money from my 2500d. Are you doing a special on the saz-1500d???????//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
whats it do 2 ohms stereo?
i been trhinking about it for awhile....
On a bad day these produce 125 x 2 @ 4 ohms at regular car voltage. If this amp were rated at 14.4 volts I would probably rate it more like 140 x 2 @ 4 ohms and 280 x 2 @ 2 ohms.
Use those numbers to compare to other amps. It's really a very strong amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif It uses six large Sanken transistors per channel and enough power supply FETs to support a 1000-watt amp.
Question in the PDF it says you can run it tri-mode. I've read this on other amps.
How do you figure what kind of power you are running at then?
Say I have 2 4ohm speakers, and a 4 ohm sub, how much power those each speaker get?
I'm also assuming that in that setup I would need a passive filter for the sub so that it just see's the low frequency's.
Bump for an awsome amp, by far my favorite amp. This amp will take tons off abuse. I have never had a single problem w/ any SAX-100.2's. I have ran mine 2 ohms bridged before with zero issues. Its powered plenty of different componet sets with ease. Its also been used to drive a bunch of different subs from a 8w7, DD 1508, Assassin, RSD10 and much much more. I have clamped mine doing over 500rms @ 4ohms. Anyways bump for an awsome price and dont forget the CS.
i know it isnt "stabls" , but if i have ac blowing on it, can i run it at 1 ohm stereo?
id like to do something like that...
Megalomaniac
Mr.SQ
Megalomaniac
The Colony, TX
sundownz
