Speakers Too Soft
awsamia
Houston
My JL XR650-cs's seem very soft compared to friends cars even with stock speakers. Turning the volume up all the way on my headunit doesn't cause any distortion but I don't feel like it's doing what I want. Would you recommend getting new speakers? I'm very dissapointed in these. Or should I put in some rear-fills to make the system louder.
that amp is 50x4. run the 2 front channels to the mid input on the crossover. then run the rear 2 channels to the tweet input on the crossover. switch the little jumper to bi or biwire or biamp, don't recall what it's labeled as. then see how it does. what is the crossover set at? turn it down to about 60hz and they'll spank //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
By saying too soft I get two ideas. One is there just isnt enough volume and two is lack of frequency response.Like Gsteg said, we could use a little more information as if its just volume or frequency related.
Sorry for not being clear. By soft I meant volume. It takes the volume on my HU to be turned up to 40 in order for the volume to be anywhere close to loud. And the highest the HU goes is 50. Being in friends cars with systems, they turn their HU up only about halfway and it's blastin.
I don't know what the gains or anything are set at but my install was done by a very reputable installer and I'm sure he did them right.
I do know that he bridged the amp to 2 channels and has one on each crossover.
I highly doubt it's the install. This guy does great work and MoeLester and NizAsianMonk can vouch for that.
Could it be that the amp is not enough?
hrm..4ohm mono, that amp should be doing a bit over 140w per channel at most.
Check the polarity on the mids. See if they are out of phase or not.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
I would not opt for the inexpensive Focal's (and I've used/use currently - their products extensively in both car and HT applications) and while a...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
224
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
115
38
awsamia
awsamia
Houston
GSteg
    May 19, 2024
    May 19, 2024
