Speakers making CDplayer noises?
Uhm. If you feel like taking your HU out.. check for any wire crosses, and if anything's amped up, change your ground. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I would swap out rca (just to be shure), Check those grounds. I have also found "noise" through a dirty switch in electronic crossover. Check those grounds
My.02...Wayne
engine noise is right! but it can be cause by a lot of things! Checking the ground, power, and rca cables on the cd player and the amp would be good! But sometimes the cd player just gets old and worn out and starts to give off the noise!
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
182
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
95
38
standard
standard
watervliet, NY
beastyle
    May 16, 2024
    May 16, 2024
