Speakers Hissing
Sounds like a problem with the EQ to me. Which one are you using?
AutoTek 7007 - That is what I'm thinking as well.
Did the problem start when you added the eq?
Yup.
Update: I've managed to get it somewhat work.
  • Added ground loop isolators.
  • Separate grounds for EQ and HU
  • Beefier wiring (Was using some crappy thin wire before)
  • Power directly from my distribution block to EQ
  • RCA's moved to right side of car from center, and away from remote wire
  • Grounded RCA's at amp and HU
Problems Left:
  • Still a slight hiss, but not noticeable when engine is on. - Definitely not my gain, as the gain is set at the lowest and is still getting plenty loud at 15 volume on HU
  • Whine introduced when EQ input goes above 1/4.
Knowmadic
Knowmadic
Winchester, VA
joselr3668
AJ (ACE)
    Jun 28, 2026
