Speakers cut out at high volume
Konstantin
I just finished installing my new system and it works, unless I turn up the sound. My radio goes to 35 but it cuts out at anything from 17+.
The current setup is:
Rainbow germaniums up front
Polk Momo mmc650 in the back
alpine pdx-4.150
alpine pdx-1.600 (not hooked up yet)
radio is Kenwood Excelon x991
If I play at normal volume, it works fine. All speakers sound ok, and I have no noise/engine noise whatsoever. What does happen is that when I turn on the car and radio I hear a pop noise, could this mean a bad ground?
The amp is not going into protect mode because it as a blue light, and it doesnt blink or turn red to indicate malfunction. Also, the radio keeps playing (the song time goes on), and gives no errors.
I will try grounding the HU directly to the car tommorow. I am pretty sure everything is wired correctly since I took special care to cut the wires just the correct length to not expose any of it.
What else could I check?
As in, gains? They are pretty low, but tommorow I will set them to minimum and see if this still happens.
The speakers dont clip at all, they just shut off.
Ok, so today I tried putting gain all the way down. Didnt work :p Then I regrounded my amp 3-4 times and it still made the popping noise. Regrounded the HU directly to chassis hoping it'd fix it, but no.
I ended up at the back speakers, they were causing the popping and cutting out. First I tried with the front speakers and they went to max volume without distorting nor cutting out. Once I connected only the back speakers they cut out at 24 and made the popping noise. I rewired the connections, added some wire loom (not sure of the name of this thing), connected back and voila, everything works perfect.
Gotta double check your work always.
Ok, so yesterday I went outside the city on a dirt road so there was a lot of movement and the speakers cut out again.
I dont know what the hell now, the cables for the back speakers are not touching any metal >_
What else should I check? Doesnt seem to be the grounds since once I unplug them everything works like a charm.
Edit: I have the amp set at option a, 1+3 and 2+4 channels working. I guess its the correct setting for the 4 speakers?
Konstantin
Konstantin
Chile
Konstantin
