speaker wire question
Your common sense is flawed then.
The amplifier uses a DC power voltage, then amplifies it and ends up exchanging it to an AC current. The AC current is high voltage, but low amperes. Wires limits are given by amperes, not voltage.
The wire going into the amp should be gauged as per the amperage pull which can be easily assessed by the fuse on the amp. If it has more than one, add them up.
maybe i did not make my question clear. i am not worried about my power wire being big enough for the amp to draw enough current. i was asking about the speaker wire from the amp to the subs.
10 gage is good in my opinion, I have 8gage wire on my subs, not cause I decided on this size but it was used after I upgraded to 0 gage.
10 AWG is a lot. 12 AWG it a lot, too. 14 is good, and 16 is less than nominal.
I mean, you can use any size. But, I suggest 12-14, depending on the amp.
The bigger the better, haha its always better to have less resistance. More power to your sub, although the difference is usually not audible from like 12 awg to 8 awg. I use 8awg just cause I had some left over from my early days when I used that as power wire.
in this case i would say going bigger isnt gnna do jack, ur just wasting ur money.
Now if ur running tons of powers, i would say the bigger the better
Yes exactly, its useless unless you already have it laying around like I did. So like I said it isnt audible, so no need to do it unless you want to get that extra 1/4th db which he isnt going to be competing most likely.
You wouldn't even see a 1/4 db gain. Anything over 12ga speaker wire is purely for aesthetics for the vast majority of people, including everyone in this thread. If you are running larger than 12ga speaker wire and think you are doing it for anything other than looks, you are just fooling yourself.
Wire capacity is determined by both voltage and amperage.
Wrong there, wire capacity is determined by amperage, insulation capacity is determined by voltage.
If you take a 1/0 wire rated for 600 volts and one rated for 15,000 volts the copper is the same size but the insulation is different.
You do realize that power is voltage * amperage right? Im sorry, but voltage and amperage do both affect the capacity of a wire.
You do realize your arguing this fact with an electrician? Take your house for example, 120v circuit #14 wire will carry 15A, #12=20A, #10=30A, #8=40. That same wire on a 240v circuit- #14=15A, #12=20A, #10=30A.... Are you seeing the pattern?
Borrowed from http://www.allaboutcircuits.com/vol_1/chpt_12/3.html
COPPER CONDUCTOR AMPACITIES, IN FREE AIR AT 30 DEGREES C
INSULATION RUW, T THW, THWN FEP, FEPB
TYPE: TW RUH THHN, XHHW
Size Current Rating Current Rating Current Rating
AWG @ 60 degrees C @ 75 degrees C @ 90 degrees C
20 -------- *9 ----------------------------- *12.5
18 -------- *13 ------------------------------ 18
16 -------- *18 ------------------------------ 24
14 --------- 25 ------------- 30 ------------- 35
12 --------- 30 ------------- 35 ------------- 40
10 --------- 40 ------------- 50 ------------- 55
8 ---------- 60 ------------- 70 ------------- 80
6 ---------- 80 ------------- 95 ------------ 105
4 --------- 105 ------------ 125 ------------ 140
2 --------- 140 ------------ 170 ------------ 190
1 --------- 165 ------------ 195 ------------ 220
1/0 ------- 195 ------------ 230 ------------ 260
2/0 ------- 225 ------------ 265 ------------ 300
3/0 ------- 260 ------------ 310 ------------ 350
4/0 ------- 300 ------------ 360 ------------ 405
Note that it doesn't say anything about voltage.
Amperage is derived by [watts * volts], so Im not following what your point is.
springer
springer
Wichita Falls, TX
audioholic
