speaker wire gauges
i found a whole bunch of 16 gauge wire left over from my home theater setup, so i thought i might as well use that. i dont know where i would go about buying 12 gauge wire locally. i thought of magnolia audio video, but it was pretty pricy there.
When you double up a wire size, subtract 3 from the gauge. So two 16-gauge wires combines for 13-gauge.
That is correct
Furthermore on full range speakers, bi-wiring is very popular and also using different sized strands in the cable can play a roll in better frequency response. So if you had some fine strand 14 gauge and added coarse strand 16 gauge, it could provided better response - will you "hear" it, I do not know, but an RTA could indicate it.
That is correct
hmm do you have the technical info behind this?
after doing some reading, it seems that bi wiring can help improve sound quality. i might actually try it out to see. but instead of putting 2 strands of 16 gauge together...im thinking of doing 3 16 gauge wires for each totalling a 16/6 wire instead of a 16/2 standard wire. i was also thinking of doing it with cat 5 cables, ive seen cat5 cables used in home theater applications. it looks crazy.
I do not have any tech info, but it has been proven that some frequencies travel better on different sized conductors. Again, I do not think you will hear a difference in a car, especially while driving and certainly not with the extensive sub use we enjoy in car audio
soul05
cookies or death??
soul05
San Francisco
soul05
