Speaker installation (Mids/Highs):
bizkit11
Hey guy's,
This might be a couple of dumb question but I need to ask. First question how do figure out which is the positive and which is the negative on the factory speaker's. For instance mine has a brown with blue strip and the other is yellow with a blue strip? Is there a piece of equipment I can use to determine without the owner's manual in front of me? Second question what kind of sealer should I use to seal my aftermarket door speakers. I noticed that on the factory one's there is some kind of black sealant that's around the ring and I would like to have the same setup on my aftermarket speakers. Any advise would be great and thanks in advance.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
some soundeadner woudl prly help seal it pretty good
put a AA or 9v battery on the stock speaker look at which wire goes to positive on batteyr which goes to negative if the speaker pops outward when u hook battery up u have it correct, if speaker pulls in when u do it u got it backwards
Hey guy's,This might be a couple of dumb question but I need to ask. First question how do figure out which is the positive and which is the negative on the factory speaker's. For instance mine has a brown with blue strip and the other is yellow with a blue strip? Is there a piece of equipment I can use to determine without the owner's manual in front of me? Second question what kind of sealer should I use to seal my aftermarket door speakers. I noticed that on the factory one's there is some kind of black sealant that's around the ring and I would like to have the same setup on my aftermarket speakers. Any advise would be great and thanks in advance.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
color coding should be in your car manual or on the instructions that came with your. aftermarket harness. On the few HUs I've owned, it tells you on the wire. It's small as hell, but it's there. you might be able to look it up online.
bizkit11
bizkit11
Cocoa, Fl.
TurdFergueson2
