Speak Peak
Did you ever get the issue with the amp resolved? And what did it end up being? because your description sounds exactly like what my amp is doing right now.
And that door looks like its going through a hurricane, god dam.
Low battery voltage. One amp was gained up higher to put out the same as the others, and because of that, it was always the first to go into protect.
Hasnt been happening since I got my alternator in. Still havent really gotten on it loud since Ive gotten the alternator installed though, havent had any reason to. So Im not really sure if its that much louder.... The amps are seeing 12.9-13v at rest now though. Still sucks, but is much better than the 12v they were seeing at rest before. I guess the alt and little charger being on all the time IS doing something.
Alright thanks, I'm runnin like 1200+ on a 60 amp alt and crap battery, but I'm switchin that out for a YT asap so hopefully that stops it
Sick build man, get some more flex vids up //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Yeah, I was trying to run 18,000 on a stock 85 amp alt for a while. Doesnt work. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Borrowed a bigger battery charger... So we will see if this helps at all.
you need a cap bra maybe even 2 or 3!!!!!! then that shit will wang and blow out your back window !!!!!!!//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:emb://content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
hope you wernt serious there bra
Theres numbers posted somewhere already... Not anywhere near what it can be with batteries that are all messed up and cant take a charge.
Thanks on the compliments... Lost quite a bit. As of yesterday Im like 6'5 200lbs.
kinda defeats the purpose when you just cant post them like a normal person
instead of saying they're somewhere, how about just saying what they are
you've been so vague and never giving a direct answer regarding alot of things, and its rather annoying when you're trying to find a simple answer
galacticmonkey
Wants a button like that.
galacticmonkey
Tampa, FL
LDW3RD
