Sp4 sealed or team ported
Lschevelle
I just started a new build and the only thing I'm missing is subs. This time around I'm not going for all out spl I want sq. I'm aiming towards a ground pounder. So my delima is three sp4's sealed or two team Fi's ported. With setup will be powered with two ampere 5k's
Don't go sealed......
If anything, do two SP4's ported and spend a little more on your electrical system to support the power you plan to run. Can get VP 7k's for about the same price as the Ampere 5k's too
I love the low end and flat response that sealed boxes produce
i've argued this for years. as long as you keep the group delay and phase between the rear and front wave distortion below the audible levels the ported box kicks its ***..
speakers have come a lot way and engineering as acoustics have as well..
Sealed you loose output and it doesn't make it sound any better. Ported is just better all the way around
Yep
With the amount of power you're running, why would you want sealed? properly Designed ported would be better.
With 10k, you're outside the typical "SQ" range of things
One of the reasons I wanted sealed was because I was going for power and cone area. And the fact that I'm not going for sheer output. With that being said I want something that plays music daily
Going for power and cone area, not sheer output.......
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
What I meant by that was..I'm not going for numbers like a lot of guys do
Lschevelle
Lschevelle
LA.
Papermaker85
