06gtmike 10+ year member
Tn1.1200d
RMS Power Rating:
4 ohms: 660 watts x 1 chan.
2 ohms: 1050 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
Dash mounted remote gain control
Double sided composite epoxy PCB
Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
Mono channel operation
Delayed on/off circuit
Variable low-pass filter (40-220 Hz, 12dB/octave)
Subsonic crossover: 20-38 Hz (12 dB at 15 Hz)
Signal to noise ratio: 106dB
Three-way protection circuitry
4 gauge power and ground wiring is recommended for installation
Included adapter accepts up to 0 Gauge
Dimensions: 6.75"W x 12.75"L x 1.75"H
Tn4.900d
RMS Power Rating:
4 ohms: 150 watts x 4 chan.
2 ohms: 225 watts x 4 chan.
Bridged, 4 ohms: 450 watts x 2 chan.
4 or 2 channel operation
Variable high-pass filter (20-4,000 Hz, 12 dB/octave)
Variable low-pass filter (50-5,000 Hz, 12 dB/octave)
Subsonic filter (24 dB at 15 Hz)
Three-way system protection
4 gauge power and ground wiring is required for installation
Dimensions: 6.875"W x 8.875"L x 1.75"H
Both are in perfect condition, only have about an hour of play time. Come in original boxes with all accessories except mounting screws which got used and misplaced.
Price: $240 shipped conus only, not looking to split up. No trades at the moment.
Tn1.1200d
RMS Power Rating:
Tn4.900d
RMS Power Rating:
