Soundstream Tn1.1200d and Tn.4.900
06gtmike
Tn1.1200d
RMS Power Rating:
4 ohms: 660 watts x 1 chan.
2 ohms: 1050 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
Dash mounted remote gain control
Double sided composite epoxy PCB
Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
Mono channel operation
Delayed on/off circuit
Variable low-pass filter (40-220 Hz, 12dB/octave)
Subsonic crossover: 20-38 Hz (12 dB at 15 Hz)
Signal to noise ratio: 106dB
Three-way protection circuitry
4 gauge power and ground wiring is recommended for installation
Included adapter accepts up to 0 Gauge
Dimensions: 6.75"W x 12.75"L x 1.75"H
Tn4.900d
RMS Power Rating:
4 ohms: 150 watts x 4 chan.
2 ohms: 225 watts x 4 chan.
Bridged, 4 ohms: 450 watts x 2 chan.
4 or 2 channel operation
Variable high-pass filter (20-4,000 Hz, 12 dB/octave)
Variable low-pass filter (50-5,000 Hz, 12 dB/octave)
Subsonic filter (24 dB at 15 Hz)
Three-way system protection
4 gauge power and ground wiring is required for installation
Dimensions: 6.875"W x 8.875"L x 1.75"H
Both are in perfect condition, only have about an hour of play time. Come in original boxes with all accessories except mounting screws which got used and misplaced.
Price: $240 shipped conus only, not looking to split up. No trades at the moment.
where were u at when i was amp shopping last month?,, so everyone knows the 1200.1 is almost the exact same amp as my ppi, i'd say it's exact same amp but the 1200 did test out about 100rms more than mine but the guts look like twins.. good amp..
May I ask why such a short usage time?
My car isn't driven at all, usually take my wifes because of baby reasons. I have some Phoenix gold Xenon's I'm gonna install that have been sitting in the closet and was just getting up the motivation to do it since they're huge and will require a good bit of work to get them to fit were I want them so these came out.
Yes, this pair has much more power than the BA2200.5. They actually produce way more than I need and that 5 channel is half the price of this set. However, you raise a good point about extra overhead available. My initial draw to the Black Ice series was the class A/B full range channels, convenience of a single chassis and balanced inputs. Has anyone heard the two differing SS/PPI series (full class D vs A/B)? Side note, Mike is there any warranty left on these amps?
I think it was a one year factory warranty from when I bought them which was close to a year ago so probably not. Most of the time they don't transfer anyways. If you're looking for a warranty then I would definitely look into buying new.
06gtmike
06gtmike
Williamsburg, VA
06gtmike
