Soundstream head unit problems. HELP!!!
I've just installed a Soundstream VIR3200 head unit ( along with Soundstream speakers, 2 amps and a sub) I'm very happy with the install in my 2010 Dakota. The problem is the head unit is not working. I know it's getting power because the light behind the detachable face blinks and I'm able to insert and eject a cd. But once I close the face plate.....NOTHING! It's a touchscreen face. It doesn't light up and no sound. So I can't even turn it on to check the amps and speakers. I've tried the reset button. It feels like it connects good when I close it...... Any ideas? Plz Help!
Ok I ran it directly to the battery and it works great. Thank you thank you. Now where do I run the stereo power wire to. Do I run it to the fuse box under the hood? And if so which fuse do I use. Several of them say ignition......-ignition off draw/cabin/radio -run start ignition switch - audio amp - power outlet - ignition run / start feed - ignition run/ ac / windows - ignition run feeds???.......and do I just pinch it with the fuse? Sorry but I don't want to fry anything. Thanks again for your help!!
I ran it to the fuse marked - ignition off draw/ cabin/ radio..it turns on but it doesn't turn off when I turn the truck off or even when I take the key out. I have to manually turn it off.should I try a diff fuse? If so which would u try from the choices two posts earlier?.......Also when I do turn the radio off I get a very loud surge through the speakers. Im assuming it's from the amps shutting off. I'm afraid they might get damaged. What might be causing this? Thanks in advance for any advise!
Sdrolan
Sdrolan
Cape Coral, Fl.
garychoffmann
