Soundqubed Q1-1200.2 Issue
Hey guys! I'm gonna start this my telling you everything I have.
Pioneer 6700bt headunit
American Bass Xfl 12 in a custom 2 cubic foot box tuned to 32 hz
Knuconcepts 4 gauge power and ground. 12 gauge speaker wire and Krystal RCA cables.
Second skin audio damplifier pro in the trunk.
So I just received my soundqubed 1200 this morning. I set my gain with a DMM. I followed these steps, How to Adjust Amplifier Gains Using a Digital Multi-Meter | Learning Center | Sonic Electronix
Anyway, when following these steps the sub barely seems like its on. I can barely and I mean barely hear it over my stock door speakers. I'm not sure what the problem is. I have to turn up the subwoofer control function on the headunit in order for it to be loud at all, but I don't want to do that since I set the gain with a DMM in order to keep it from clipping. Is the DMM not very accurate? Did I just get a bad amp? I fail to see how a 1200 rms amp would not be able to push an xfl. When setting the controls on the headunit higher and set the gain a bit higher the amp puts out some serious power but I'm afraid it is clipping. Any suggestions? I have emailed soundqubed but I dont think they will get back to me until monday. Am I just being paranoid and it's okay to turn up the headunit controls? I just can't wrap my head around the fact that everything on the headunit is set to be equal, the amp gain is about 70% turned up and the amp barely pushes the sub at all.
Hey guys! I'm gonna start this my telling you everything I have.Pioneer 6700bt headunit
Check your filter settings maybe? Not sure
Turn the sub control up. Keep bass boost off the deck is a 4 or 2 volt pre out nate ? Also check sub phase
Sub control wont cause clipping then? The deck is 2 volt I just put it in a few days ago after my Pioneer 8500bs gave out. It was 4 volt //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. Also I know this is probably a dumb question, but what is sub phase?
Make sure the sub is wired correctly. Also a 2 volt deck. You'll need to turn things up a bit
The sub is wired correctly, and yeah I wish my other one didn't give out, but would it really make this much of a difference? So setting the sub control higher won't hurt anything?
No it won't. But you'll need to recheck with the dmm when done
Looking to buy 1 Soundqubed hdc4 15” basket/ frame with gasket.
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
nategearing42
vienna illinois
nategearing42
    May 31, 2024
    May 24, 2024
