Sound stage
If you decide to put the mids in the doors I would put the tweets up top facing the opposing headrest. Also a headunit with time alignment will change the perspective of where the sound is coming from.
don't aim those tweeters on axis, fire them straight across dash at each other. Get a dash mat, play around with the phasing and start off with the mids in the kicks. make sure to seal the old tweeter hole.
I could put some tweeters in the factory locations.
pd.OIHBnI
For some reason the image isn't loading from my iphone
im guessing you picked your equipment up from davids car audio in br . id say get them to make dash pods for the tweets but theyll prolly charge you out the rear. maybe try innovative in denham springs, mobile one out of the new orleans area did some great work but idk if there even open any more
Update**
Looks like I found a good installer. He is going to use the kicks as a base and build them up. Remove the tweets and relocate them to the A pillars facing each other.
let me get this correct. you have the midrange and tweets in the kicks. do you also have some mid bass in the doors?? you can keep the midrange and tweets down in the kicks. I have them that way and it sounds very good. this is how I have mine
you also have a very different car
i was just using it as an example since he feels that he needs to move his tweeter to the top and buy mats and all of that. I know its different cars and different equipment but it cant be that different to the point where it cant be used to give an idea..
da0s44
da0s44
Baton Rouge, LA
da0s44
