Item(s) for Sale: 15" Sound Splinter rl-p D2
Item(s) Description/Condition: This sub is in great condition. I had purchased it from a one owner who had used it in a home theater set up. I purchased this sub a while back to use in my car, but once the enclosure and sub came in, I realized I had went a little over board. I ran this sub at 500 rms @ 1.3 ohm while in my car and it sounded great. The bass was just too much for my little car and the enclosure needed to house this sub is just too large. A single 12 is all I will need. So I'm selling this sub only because of poor planning on my part. The sub is dual 2 ohm and reads 1.3 ohm in parallel and 3.9 ohm in series. It is a great sound quality sub designed to get both loud and low and will work well in ported or sealed enclosures. Specs are as follows:
SPECS:
Dual 2 Ohm
Qts: 0.333
Qes: 0.363
Qms: 4.032
Fs: 23.426 Hz
Re: 3.66 Ohm
Ls: 5.236 mH
Rp: 10.46
Vas: 163.0 L
Mms: 290.9 g
Cms: 158.6 u
Bl: 20.76 T*m
SPL: 89.43 dB
Sd: 0.0806 m^2
Xmax: 24.6 mm
MEASUREMENTS:
Mounting Depth: 17.5 cm
Total Depth: 18.5 cm
Outside Diameter: 31.8 cm
Weight: 35 lbs
Magnet Width: 18.8 cm
Mounting Cutout: 35.5 cm
Displacement: 0.18 cu ft
Price: I'm asking $275 shipped.
Shipping and Miscellaneous Item Information: I'm going to pack the sub in a cube of 2 inch thick styrofoam so it will be well secure and protected during its travel to your door step. As well as being inside a sturdy box! The sub will be coming via FedEx Ground.
SPECS:
Dual 2 Ohm
Qts: 0.333
Qes: 0.363
Qms: 4.032
Fs: 23.426 Hz
Re: 3.66 Ohm
Ls: 5.236 mH
Rp: 10.46
Vas: 163.0 L
Mms: 290.9 g
Cms: 158.6 u
Bl: 20.76 T*m
SPL: 89.43 dB
Sd: 0.0806 m^2
Xmax: 24.6 mm
MEASUREMENTS:
Weight: 35 lbs
