- Thread Starter
- #46
Grn-eyed devil, I am a computer whiz kid, and I know exactly what I am talking about when I mention this stuff. On computer soundcards, the 3.5mm outputs are analog outputs with 16-bit/48kHz sampling rates, while the higher-end fiber optic outputs have a sampling rate of 24-bit/96kHz. Let's step away from that for a second. An analog audio signal is usually a 2.4GHz RF signal, while a digital signal is usually a beam of Infrared energy, which can run anywhere between 300GHz and 1,000THz. There are two purposes for IR, one is to detect heat (high-frequency IR) and the other is to amplify very low existing light (low-frequency IR). Most digital audio signals are low-frequency IR signals between 300GHz and 10THz. The human ear can detect frequencies between 20Hz and 20kHz, while the human eye can detect frequencies between 600THz and 900THz, which is high-frequency IR, not ultraviolet. Ultraviolet is 1,000THz to 120,000THz. Since the digital signal is transmitted as a beam of light, it is at a much higher wavelength, and therefore a much cleaner signal than an RF signal. The downside to smaller wavelengths (higher frequencies) is more power is needed to transmit the higher frequency signal to the same distance. An uncooled IR transmitter has at best 25 feet maximum range @ 12V, while an RF transmitter can get up to 1,000 feet or more with 12V. 2.4GHz is microwave radiation, and microwaves cook things by sending that 2.4GHz wavelength into the material, which causes the material to vibrate and heat up. The same thing happens to the human body when it is exposed to microwave radiation, which is why there are regulations on the use of RF devices like cell phones, cordless phones, or wi-fi cards. If you want an idea of just how dangerous a 2.4GHz signal is, stand in front of a large radar dish while it is transmitting and watch what happens.
