Sound deadening
What Product
  • Reamat BXT 62.5 sq/ft $139.95
    Votes: 16 72.7%
  • Ensolite
    Votes: 0 0.0%
  • Secound Skin Luxury Liner 9 sq/ft $60
    Votes: 4 18.2%
  • Vertex Barrier Pad 45 Sq/Ft $250
    Votes: 1 4.5%
  • Dynamatt 12 Sq/Ft $140
    Votes: 1 4.5%
  • Total voters
    22
what about protecto wrap. its a butyle rubber with a layer of aluminum. it runs 14 bucks for a 6in by 25 foot roll
If you can find it, it isn't terrible IF you get the butyl adhesive with aluminum foil version. Keep in mind that they also make asphalt versions and versions with a useless for sound deadening poly facing. Also, it is flashing tape and MUCH thinner and lighter than real sound deadener. Since you will have to at least double the layers, the savings starts to disappear and the labor starts to double along with it.
Price per square foot means nothing. You really need to consider the materials, their properties and how heavy the product is.
How well will a roll-on bedliner material stick to sheets of sound deadener? I would like to roll the inside of my truck's floor once i get the deadener layed in.
Never tried it, but water based liquid deadeners sticks very well to the aluminum faced deadener so unless it cures absolutely rigidly, I can't imagine what the problem could be. Try it on a small piece?
Ok, I'll try it. Im also concerned about the life of the bed liner material. How will it hold up 6 months or a year from now when it is rolled on the deadener. Ill just try it out on a small piece if i can.
EDIT::: another issue i see coming is that the deadener is not as stiff as a metal bed floor, and it will probably flex and move when I put my feet on it. I could see it cracking after a while maybe....
thanks,
Cody
That would work great.
We sell a lot of sound deadening to Jeep owners that use no carpet in their rides.
Usualy they do a layer of Damplifier or Damplifier Pro onthe sheet metal then apply a professional 2 part system like Inyati, Line-X or Rhino liner on top.
It works out really well.
Bed liners alone don't do much in the way of sound deadening but they do add weight which helps lower the resonant frequency of the car, and they add strenth to the foil on the CLVED which helps increase the sound deadening results from the butyl/foil combo.
Hope that helps
ANT
http://www.secondskinaudio.com
That would work great.We sell a lot of sound deadening to Jeep owners that use no carpet in their rides.
Hope that helps
ANT
Ok. sounds like a plan! I just need to find a Line-X or Rhino liner that I can do myself and not have to have it done for me. I wonder if they have a roll in style.... because I dont have capabilities to spray anything unless it came with a sprayer.
Thanks a lot
Cody
Thanks a lot
Cody
You wont be able to find one.
Professional polyuread bed liners like linex and rhino are 2 part systems that cure almost imediately once mixed. The gunthey use is quite a complex one that mixes the 2 parts while shooting them.
Anything you find in the aftermarket like hurculiner will be a 1 part systsem.
Not nearly as good.
We have a formula for a single system bed liner that blows everything else on the market away, but when compared to a real 2 part system it is no where close.That is why we have not brought our bed liner to market.
Second Skin is know for having the best products around. To come out with the best single component bed liner would be cool, but soon as it would be compared to Inyati, we would be murdered...
ANT
Not nearly as good.
ANT
good info.
Edead no longer has ANY asphault in it. Jesus get your facts straight. They only drawback that some people see is that it just has mylar on top and not thick/stiff aluminum which makes the constrained layer effect from multiple layers not quite as effective. The cost clearly outweighs this drawback.
I disagree. Constrained layer damping has nothing to do with multiple layers - it is a critical component of vibration damping that relies on the stresses between the adhesive and the foil. No foil = no CLVED. You'll need multiple layers of a Mylar faced material to equal the performance of a single layer of a foil faced product. Extra layers eliminates the cost savings and increases the work required and the weight added for no good reason. Price/ft² is amueaningless metric for sound deadener.
eDead v1² is the first butyl mat to have a significant number of reported adhesion failures.
B16BCivic
B16BCivic
Canada
audioholic
Mike Mccabe
Giles
    Jun 27, 2026
