So you think I can get away with using both 6.5 mids, one for mid-bass and one for mid-range?If u can seal the mids furthest from you and have enough air space, then do that and use those for ur midrange. Reason for that is so the 'violent bass air*' from the midbass won't distort the midrange driver.
*Vestax would understand
And LOL @ mr. Turd. There's more sarcasm in store //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I cant though right now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I dont have anything to separately power the other set of mids with.Well, since you don't have a substage ATM... run 3 way active on your HU for the front stage.
1 pair of mids for midbass, one for midrange, and then tweeters for highs...
nG
Do that. Dont cross it over lower than what the specs list for that speaker so high pass it all at like 50-60hz (guessing) from the HU or whatever would work. Obviously use the mid that isnt angled towards the driver as the midbass.Well, since you don't have a substage ATM... run 3 way active on your HU for the front stage.
nG
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif that's awesomeMake it sound the way YOU like, **** everyone else. This stereo is for you right? But it would sound a shitload better if you follow the advice given on here.
I think Im gonna pull the inner set for now, and then get an h701 and do like the above ^^^I can't believe I missed all of this since my last post.
Yeah good thinking. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifStop stop. You want to go somewhat active, then do passive for the remainder? What is your goal? Think about that and do things to achieve it. Don't get little quick fixes while saving money for the final thing. Its a waste.
-Figure out your goal
-use logic and research to figure out what parts you want/need
-ask for reviews and research it before you buy
-research and survey possible and better mounting locations available for the equipment you plan to use
-revise equipment list if something cant fit (better than to go smaller than force something you want)
PUT IT IN!
