Sony XM-2020 Amps (x2)
btolenti
Tiny Sony old school amps, rated at 20x2 @ 4 ohms. Was planning on using these for my front tweeters and rear fill, and instead went with a single amp solution for my install (JL G6600). Both amps tested good and played surprisingly loud and seemed very clear and warm sounding. The darker colored one will come with the full harness (seems to be uncut) and the small mounting bracket. The gray one doesnt have a mounting bracket (but can be easily double sided taped or velcroed down), and the wiring harness is shorter (still plenty of wire left on it though).
Specs: https://docs.sony.com/release/XM2020.PDF
Asking $25 for the light gray one and $30 for the dark gray one shipped.
See above.
10-4 these would work great for me but I'm running above 2v on the input. ***** cause I'd really like to us these.
Anyway at least these posts bumped your thread a little glws!
Have you tested your preout voltage? Ive found a few decks are rated for 4V output, but aren't actually.....
843
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
973
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
btolenti
btolenti
Orange, CA
btolenti
    May 31, 2024
    May 24, 2024
