Sony Explod HELP!!
94ranger
I got a Sony CDX-M610 head unit. I hooked the power source to the radio up and the radio turned on automatically. Thats cool, but... none of the functions on the radio work! The face dont flip up when I hit close or anything, even source dont work! Whats wrong here?!?!?!?!
The only thing that does work is the Clock... I check fuses. If the wrong number fuse is in the wrong spot will this matter?
Please respond tonight...
Originally posted by Natheo more than likely //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif .
What's the problem? The quad 20 bit burr brown DAC's, the full copper shielding, or the 110db S/N Ratio?
734
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
934
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
94ranger
94ranger
South Jersey
B&R Innovations
    May 18, 2024
    May 18, 2024
