No need for that. Since you are dealing with a circular form, vibrations are spread evenly around the circle and because it's a circle there is no expansion.Looks good but that cant be very strong, the walls of that tube are cardboard and there isnt any fiberglass in there to reinforce it.
Take your time using the jigsaw and you will be fine. Use silicone to seal the enclosure.the only thing im worried about if I were to do this, is if my baffle or end cap were even just a little bit off there would be a leak. Plus I don't have a router so if I used a jig saw i'd have to make a perfect cut.
?I would assume it depends on the install. Being right on the edge some waves might roll off the side and create issues. Though being in a small trunk that might not make much of a difference...
Nope. See above.No reinforcement? Shoulda put a couple layers of glass on it. Having a cardboard enclosure means its going to flex like hell.
^ Yes, but there is a lot of pressure inside of a sub enclosure and you dont want the walls of the enclosure to distort.
No matter how you look at it that is a cardboard sub box. Not to mention it is barely being held on by a pair of wood screws going through some sheet metal....
Im not trying to hate on the OP's stuff here, but Ive used those tubes before and I would never consider using one as an enclosure unless it was reinforced.
Haha, I was waiting for you to see this. Glad you like it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifLooks like a good build. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nope. See above.
Here's a link to my writeup on it:
http://www.caraudio.com/forum/showthread.php?p=6031097#post6031097
Which is why I did the strap test myself, to test the theory of reinforcement to none.There is no need for any reinforcement of these tubes. Believe me, I've been down that road and found no advantage whatsoever using any type of reinforcement.
Good point, seeing as there is uniform pressure. Still scares me a little bit though.Picture several thousand pounds of concrete filling a cardboard tube 24" round with 3/16" thick walls. I don't think a sub could duplicate that much pressure.
