traksta15 10+ year member
I love lamp.
i would put it sideways, that would look almost stock...
great install man, def out of the ordinary!
The MDF is glued in with heavy duty construction adhesive, the kind that comes in a tube similar to caulk. I also put 6 screws into the sides of the baffles for reinforcement.So it's just a 14" x 22" sonotube?3 3/4 MDF rings? How did you attach these? Are they just standard size for a 15"? ( I **** at cutting so way just going to buy some, but I guess I would still have to cut the back side Hmmm )
I am wanting to make one but fiberglass it. Any idea how much the sonotube would be to buy since you got it free and where to get them? Lowes maybe?
I don't have a sub amp. JL subs are powered by the dreams of small children.were the amp be?
i was waiting to hear a drive shaft off the trans that drives a crank inside the box. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifI don't have a sub amp. JL subs are powered by the dreams of small children.
Nah j/k it's under the driver seat.
I would assume it depends on the install. Being right on the edge some waves might roll off the side and create issues. Though being in a small trunk that might not make much of a difference...i was under the impression that the tube should be a few inches wider than the diameter of the sub? does anyone know if this matters?
