something wrong please help
  • 5
kevin lu
727south
i went to work today everything was fine but when i got off and get in the car turn on the music the bass is keep going in and out so i pop the trunk i see the light on the amp go green and then go red keep flashing, do any one have this problem before? thanks
Perhaps, but it could be something simple like a loose wire, bad rca, etc. If it is cutting in and out the wiring would be the first thing I would check.
Check your wiring > buying a new amp
Bad ground. Subwoofers blown causing too low of an ohm load. Too many things that could be wrong. Getting a new amp won't do anything if there's something wrong with your wiring.
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
When I was delivering pizza the companies had to raise employees wages and in response they hired twice as many employees and cut everyone's...
14
59
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Yeah, I plan to run them in my workshop. I haven't gone through them or anything but they startup and run just fine. I don't see any strange spike...
kevin lu
727south
kevin lu
clearwater, fl
kevin lu
    May 31, 2024
    May 24, 2024
