something went wrong.....
d1champ
Car: Chevy Cavalier 2001
Setup: Alpine Type r sub, alpine amp, 1.0 Cap
I mounted my amp to the back seat, and the drill touched a screw on the amp and sparked, the fuse at the battery is in tact, i changed the fuses on the amp and i don't know what else it could be. Car started whining, so i unhooked the amp and now the alternator doesn't whine anymore.
Car: Chevy Cavalier 2001Setup: Alpine Type r sub, alpine amp, 1.0 Cap
first off get rid of that cap,they are useless,secondly we need a bit more detail,which screw did it touch?but the alt wine is a ground loop issue,which means you have a grounding problem.
yeah, that doesn't really make a lot of sense. It had to have touched more than just a screw. I would assume you were drilling through metal of the amp mounting foot or the seat and the bit touched the + terminal of the amp. Just touching a screw with the drill won't cause an arc. you had to have touched a ground and a positive source at the same time to get an arc.
does the amp power on?
check voltage with a meter at the amp.
then turn the key on and check the voltage of the remote terminal on the amp as well.
report back
d1champ
d1champ
Quincy, MA
Only The Best
Mike Mccabe
