Some Testing : SAZ-1500D and Two Z15s
sundownz
Pro Seller
Supporting Vendor
During the 150.0 dB run the 1500D clamped 2640 watts. I am running the amp at 17.9 volts and 1/2 ohm nominal.
My meter measures about 5-6 seconds into the burp and is a True Power meter.
It says "2.55 kw" in the above picture in case you can't tell due to the blurry-ness. This was a 149.9dB run.
So... two Z15s with just a hair over rated power hitting 150.0 dB @ 50 Hz //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Not bad at all.
My favorite part about doing car audio is testing out stuff //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you are thinking "Dang... that is alot of fusing / wire for one 1500D" you are right. I had four 3000s in here before and this is just a temporary thing for testing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thatll work haha
What was the rise too?
And how much is that meter?
That meter was 230 bucks - it's awesome, though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://www.globaltestsupply.com/test_equipment/Extech_380976_Single_Phase_Power_Clamp.cfm
I bought it from these guys.
Since the meter does power all at once I don't know actual impedance right off hand - would need another measurement of voltage to calculate, which I have not done for this setup.
This box has had a very low rise with anything I've had in it, though. I've had as low as 0.87 after rise with a different woofer.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
