MeMo2
First of all. the car is VW R32 and the Fac Batt is in the back. so the wires are just 3ft
ALT 140A
I have kinetik 1800 and 600 + the Factory batt. which is 80Ah Acid one
i was installing the 600 with the Fac batt. PAC Isolator between them.
for now i bought kinetik 1800. So what would be the best way to wire them.
1- Keep the FAC batt and connect it to the kientik's 1800+600
Isolator would be between the Acid and the kinetik's
should i use fuse. between the 1800 & 600. even if its just 1ft 1/0
2- replace the Fac batt and install the 1800 . then connect it to the kinetik 600.
which i am doing for now.
or should i forget about the 600. and not use it.
also i have JBL 2200.1 amp. to power the ATOMIC APXX 12" D 1.3
i am wiring my amp parallel. and sub also parallel
so am i driving my amp @ 0.7 ohm ?
thanks for inputs.
ALT 140A
thanks for inputs.
