some general questions
  • 4
jteske88
ok so i have got everything working the way i want now so time to tune. i **** at math and cant figure out how to tune with my dmm. i have to re se 12 d4 and re audio dts.1500.1 at 1 ohm.
i need to figure out what i should be at voltage wise.
whats a ruff estimate on db's for soemthing like this? any idea or am i lost
I cant remember the math behind tuning an amplifier. I have done it by ear for the longest time, but now i just use my dd-1 to tune amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
soundmancaraudio.com has a video where they go over the math formula on tuning an amp. Cant remember which video tho :/
Not sure where and not gonna look, but there are a ton of videos on both here and Youtube that show in detail how to set your amp with a DMM. Just do a search in either place. And you wont be measuring anything in db's.
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Looks like it's wire it either 4 or 8 ohm 🤔
844
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
875
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
jteske88
jteske88
collinsville il
quackhead
    May 18, 2024
    May 18, 2024
