so I want to port my box
another question on the poly fill. Im an a/c guy and have been reading about lining boxes with fiberglass. Is this good? To me it seems it would drastically shrink the internals of the box but have read where people do this in leu of poly fill.
I've never used fiberglass for fill...I've always used polyfil batting(mat). The theory is the poly actually slows down the back wave making the enclosure 'seem' bigger, thus lowering the tuning.
cool, I have rolls upon rolls of that stuff in my shop as well, that we use for filter media.
Rule of thumb for stuffing is 1lb per cf of airspace. So 2-2.5lbs loosely placed in the box should help.
Let us know how it sounds...remember you will NEED a subsonic filter or you risk over-excurting the subs...and that's no bueno!
my amp has one on it, will that work?
---------- Post added at 02:50 PM ---------- Previous post was at 02:49 PM ----------
and how do you set those things? I was farting around with it today and got it at the 35 hz setting
Yes it will work just fine. The tuning frequency of your box is going to be around 33hz-35hz depending on the affects of the polyfil...ssf's are typically set to around 5hz under tuning freq of the enclosure...you can run yours safely down to around 28hz-30hz.
***Shameless plug for my build log***Check out my build log***
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/617930-audiofrog-gb10-gb25-dash-podz.html
//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Polar
Polar
WPB, Florida
Polar
