Yes...16.7 inches long, 4inch diameter...per 1.5 chamber will get you to 34hz tuning. What I modeled is a single sub.if I see that correctly and thank you for putting that together and taking the time to do so. I would need a 4 inch round vent 16 inches long
It would be better if you just get another custom box built. You said you have 1.4 cu ft on each chamber so you would have to have an external port to keep that internal space the same. If I were to really use that box, I would cut a large hole inside the wall separating the two chambers turning it into one big chamber. Then have an external port wherever you have space for. If you stick a port inside that box, the airspace will be pretty small and if you flare it, it will take up a bit more space as well. It would just be ideal to start from scratch and build the biggest box you can fit in there.sweet, next question. I have the subs facing forward into my back seats. Is this optimal? should I port the top, its gonna stick outta the box a bit. So if I get this correct I can port each chamber and I can flare it or whatever to make it look nicer, and itll be at 34 hz? how far do I put the tube into the box?
I compared (3) enclosures for you: 2.5cf, 2.8cf, 3.0cf all tuned @35hz. Also applied to all: 80hzlp @24db, 30hz hp @12db, and 1300rms.Im pretty hell bent on doing this lol. I cant leave anything alone plus I need my " me" time to fart around with something or I will go nuts! Any thoughts on inverting my subs to gain a little bit more internal volume? Here is how they sit now.![]()
would inverting them, of course they would have to face upwards which I have no problems with and (2) 6 inch ports 10 inches long blowing out the sides into the rear doors work? Im taking out my rear jump seats and making a rack to get my amps off the box too
//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gifthanks bud, if we ever cross paths I owe ya a round. I will do one 6 inch port 20 inches this weekend. and will re do the box covering, maybe duraliner it or something
