So I have a good old Cadence txa-300-4
JuicyJeff
Juicy
These are the specs
Cadence Sound Systems
TXA-3004
4 CHANNEL HIGH POWER AMPLIFIER
4 x 75 WATTS RMS @ 4 OHMS
4 x 150 WATTS RMS @ 2 OHMS
2 x 300 WATTS RMS @ 4 OHMS
* FREE BASS REMOTE *
SPECIFICATIONS:
4 Ohm RMS Power: 4 x 75 Watts
2 Ohm RMS Power: 4 x 150 Watts
4 Ohm Bridged RMS Power: 2 x 300 Watts
Frequency Response: 20Hz - 30,000Hz
S/N Ratio: >100 db
Damping Factor: >200 @ 100Hz
Minimum THD:
Dimensions: 17" x 9.2" x 2.12"
FEATURES:
High Speed Mosfet Power Supply
Studio Grade Bipolar Output Stage transistors
Fully Adjustable 18dB/Octave Crossover
Fully Adjustable Bass and Treble EQ Controls
Adjustable Input Gain 170mV-5V
2 Ohm Stereo Stable
4 Ohm Mono Bridgeable
3 Channel Mixed Mono Capable
Power and Protection LED Indicators
Full IC Controlled Protection Circuitry
Mute and Soft Delay Circuitr
Lucite Encapsulated Terminals
I'm looking at a Jl 12w3 on Craigslist and those subs take 500 rms. I'm wondering if this amp could work so that I can sell my p3 and my p500-2 as a set. I used to have a lot of know-how here, but my interest died when I ran out of money. Now I'm feeling like getting back in the game and want to know this basically:
If I take 4 Ohm Bridged RMS Power: 2 x 300 Watts
And put those together to the sub, I would have 600 watts at 4 ohms?
Also, With my p3 on my 500-2, I have it wired at 8 ohms. Its a 4 ohm sub. Is there a better way to wire this? Wired at 2 ohms it was poppin fuses and actin up. Would the txa be better suited on the p3, because it is a 4 ohm sub?
so this whole time, the txa coulda been feeding my p3 much more efficiently than the p500-2? As the 500-2 is running the p3 at 8 ohms
And if I power each coil seperately, isn't it bad if the knobs are a little off for each channel? I don't even know how I'd do each seperately anyways, care to explain? There's only one terminal on the back of the box.
If it were me I would take the box terminal off and rewire it so that each coil has a + and - run of wire.... That way it's pretty much fail proof for checking it out and seeing which amp you prefer //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
JuicyJeff
Juicy
JuicyJeff
Near Cleveland, Oh
JuicyJeff
