Long story short I replaced old alpine e12 sub and a dhd amp I bought 10+ yrs ago and I got the 2 items below. I got the sub first but I am thinking it wasn't strong enough to handle the amp or I just put 2 much power into it, but my settings were not that high ( or so I believe) so I am not sure if it could be some thing else. Its hooked up to a stock 2001 gs300 radio system and I control the bass with PAC bass knob and have it wired to a kicker L.O.C. in the rear stock sub.. my old system was fine up until last month when the e12 died of natural causes lol.
So here are the questions:
Did I use too much power?
Did I pair sub and amp incorrectly?
Improper Tuning?
Improper Wiring of Sub?
..ALL OF THE ABOVE..
SKAR AUDIO IX-12 D4
Sub was wired like this
Technical Specifications
Skar Audio IX-12 D4
Dual 4 Ohm Voice Coil Configuration
Peak Power: 500 Watts
RMS Power: 250 Watts
Pressed Paper Cone
Advanced Air Flow Cooling System
2" BASV High Temperature Copper Voice Coil
Motor Weight: 40 oz
Frequency Response: 25 - 300 Hz
Sensitivity: 88.1 dB
ALPINE MRV -M500
Gain was set at the notch below 1/2, lpf to 80, and bass eq to +3
Performance
RMS Power Output (Watts x Channels) 300 x 1
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 500 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged N/A
Minimum Impedance Unbridged 2
Best Frequency Response 7-400 Hz
THD at Rated RMS Power 0.2%
Signal to Noise Ratio 85 dB
Input Voltage 14.4v
Features
Amplifier Class D
Low-Pass Crossover Frequency 50-400 Hz
Low-Pass Slope (dB/octave) 24 dB/octave
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) N/A
Bass Boost 0-12 dB
Bass Boost Frequency 50 Hz
Fan Cooled No
Fuse Rating 60
Improper Tuning?
SKAR AUDIO IX-12 D4
Skar Audio IX-12 D4
Pressed Paper Cone
Motor Weight: 40 oz
ALPINE MRV -M500
Performance
Input Voltage 14.4v
Features
Amplifier Class D
Bass Boost 0-12 dB
Fan Cooled No
Fuse Rating 60
