so confused smd distortion detector?
the dd-1 detects anything besides the fundamental frequency of 40hz or 1000hz
40hz sine wave/40hz clipped sine wave, notice the harmonic distortion introduced by a +2.1db waveform
see the -10db peak at 120hz, then 200hz and so on
Who needs to mess with gains when you have 8V pre-outs and ample headroom? I just set my ish to bare minimum and use my t/a to attenuate the channels individually. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
again, harmonic distortion is different then looking for flat spots with your eyes/scope display
anyone would say the waveform below is clean and has no clipping since u see no flat spots. well guess what...? the dd-1 would light up red because i pushed it .1db into clipping which you cannot see, but the dd-1 will detect the harmonics introduced that the handy scope isnt letting you see
even audacity labels it as 0db, it takes a minuscule amount of distortion to trip the dd-1, and your eyes simply are not as accurate, as the above test shows
So you can assure absolutely no distortion at 60hz. Seems really handy if you drive around listening to 60hz tone.
Wouldn't it be optimum to test for distortion/clipping at whatever frequency impedence is the lowest your amp will see? I've measured well over 20 ohms out of a .4ohm nominal load at resonance....pretty sure what the amp does for distortion at 20 ohms or more is a bit different than what it would do at .4
Nut-huggers gonna hug.
"anyone would say the waveform below is clean and has no clipping since u see no flat spots. well guess what...? the dd-1 would light up red because i pushed it .1db into clipping which you cannot see, but the dd-1 will detect the harmonics introduced that the handy scope isnt letting you see"
well now we know to turn down our volume one click and now we know we dont need the dd-1 //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
optimusprime
roll out.
optimusprime
westbrook, ME
wenn_du_weinst
