SO bad Cops pull over when I ride by
jcixx
I need help. Well Actually I need a solution. My Lights Dim horribly. So much so thta I just do not listen to my radio at night. What I have: 2006 Charger running about 2500 watts RMS, Two 2 Farad capacitors (one on each sub amp).
What I've tried: I had an Optima yellow top but I took it out because it perfomed worse than the factory battery. I've been told a lot of different things and I'm tired of wasting money. Does any have any suggestions? Or Similar vehicle ?
I will try the BIG 3 This weekend. {I think the altenator is ok its 160 amps} Question though should I run the upgraded wires to the fuse boxes?- because the altenator is under the hood of course but the battery is in the trunk
jcixx
jcixx
Detroit, Michigan
jcixx
