Smaller pulley on Alt, negative effects?
I bought a 1 wire alt that was supposed to be 200 amps, but it didnt make close to the power I thought it would at idle, I contacted the seller before even putting it on and told them this, she told me she was going to send me a smaller pulley and that should bump up the output, will there be any drawbacks to this??
I plan on putting it inline with my a/c belt which is a 3 rib
Most all HO alts come with smaller pulley's ,usually 2".Depending on your idle speed and the size of your crank pulley you should get slightly higher output at idle.I had to go with a 1.65" pulley to get decent output at idle.
WOT
Banned
WOT
Toronto,CANADA
audioarsonal
michigan born
    May 14, 2026
michigan born
    May 14, 2026
