Hintzyboy
Sparks mean its working!
It depends on how much port area you need, what the net volume of the enclosure needs to be, what tuning you want, how much trunk space you have, etc.
Slot ports are better for large enclosures. Let's say you're building a box for 2 12s and you want 24 sq in of port area. You can either use 2 4" aeros or a 2 in wide slot port. Since you'll have already bought MDF to build the enclosure and large enclosures don't require much for port length, you'll likely have enough extra MDF to make the slot port (so you basically get the port for free). Or you could by a pair of 4" aeros for around the same price as a full sheet of MDF. Slot ports take a bit of extra work and calculation, but for a large enclosure, the cost savings are definitely worth it.
Aeroports are better suited to small enclosures. Let's say you're building a .5 cu ft (net) enclosure for a single 8" woofer. Since the height of a slot port is dictated by the height of the box, the port area is going to be larger than may be necessary for a small sub (an 8"x1.5" slot port has almost twice the area of a 3" aero). More port area means a longer port length fore the same tuning. A smaller enclosure means more port length for the same tuning. Using a slot port in a small, low-tuned box is going to require a very long port. The mdf used for a slot port also takes up airspace. All of this means that the slot port is going to increase the overall volume of the enclosure by quite a bit, defeating the purpose of buying a small sub suited for small volume. You're also not going to see the same cost savings. A slot port in a small enclosure is going to require a lot more mdf, which will likely mean you have to buy a full sheet. With an aero port, you can use a half sheet, which balances the cost of the port while keeping the overall enclosure dimensions nice and small.
Aeros also have the advantage of ease of use. You just have to cut a hole and mount vs. measuring, cutting, and glueing/screwing in the boards for a slot port. You can also adjust the tuning without ripping the box apart or building a new one.
