Flat response
download win isd and play around with box sizes and tuning to get a flatter response, its what i did for my dayton ho's, got it pretty flattened out
win isd does not figure in cabin gain, so you can model up a perfectly flat box, then throw it in a car with janky cabin gain and get no where near the flat response that you were looking for. Some subs just aren't designed to play flat to begin with.
I usually would support this claim but I recently found a feature in winisd that lets you help simulate cabin gain. If you goto the EQ/Filters tab in WinISD and goto add new Linkwitz Transform you can enter in some numbers to begin to play around with your peaks. Set the Q values to 0.707, set the f0 value to about where your cabin peaks. Not entirely sure what the fp value is, I think it's like your low end roll off or something -- just set it to 10hz. I'm still playing around with it
Hmm mine doesn't have that tab. I have version .44 (beta)
how do you find where your cabin peaks at?
Well there are 2 peaks there is one for the meter and one that we perceive. Grab some test tones and play around until you find the loudest one, it's usually between 40-50hz with the peak being closer to 50hz. Mine peaks at around 47hz
---------- Post added at 03:23 PM ---------- Previous post was at 03:23 PM ----------
Grab 0.50. I think it's winisd pro alpha
Below20hzonly
Below20hzonly
East Grand Forks, MN
etm34
